Home > Technical > L494 Purchase with issues
Wanyer88
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Hi there, i am new to the forum as i have just purchased a Range Rover Sport L494 HSE 2014 model and have the following issues, i was made aware of the issues prior to purchasing but do enjoy working on vehicles and repairing. I do understand the following items will have been covered many times but i am struggling to find the answers so thought would be easier to start my own thread.
Suspension stating only normal height available highlighted on the dash - have scanned this fault and it is stating the pump is not building enough pressure, my question is, do i replace the pump, if so best place to purchase or is there a repair kit as an alternative? The pump details are AMK CPLA 2B.
Water in the footwells, after reading the internet i do believe this is coming through the sunroof drip tubes, can anybody please point me in the direction of a repair kit or is this something i will need to manufacture myself to repair?
Airbag light on, after scanning it has come up with the error code B0028-13 Right Side Airbag Deployment - Circuit Open. Is this as simple as the connector under the driver seat?
Entertainment system not working, items on the display are greyed out and will not allow you to open the audio, phone etc. Is there a certain module that causes this before i remove all the interior to locate the fault?
I know there is a lot of questions but i do enjoy the car and will be keeping the vehicle for some time so happy to take my time and get the issues mentioned completed and hopefully try and complete myself.
Thanks in advance
Wayne
Post #639517 Fri Feb 09 2024 2:45pm
Karlp606
Good Evening Wayne,
How long ago was the purchase??? If it was within 30 days Id be taking it back to the place you purchased it from.
1. Yes the pump sounds knackered or it could be one of the air struts - you prob need to investigate further with the error code.
2 and 3. - Yes water in footwells will be a detached drain hose from the sunroof - self repair is prob a 3-4 hour job if your fairly good at diy - Check my thread here;
https://www.rangerovers.net/threads/sunroo...ge.351767/
Post #639555 Sat Feb 10 2024 7:01pm
Karlp606
PS Airbag light sounds like a loose connection if circuit open.
Post #639556 Sat Feb 10 2024 7:01pm
Karlp606 wrote:
Good Evening Wayne,
The buyer was made aware of the issues and chose to buy anyway so there isn't really a come back. 2012 SDV6 - it's missing a couple of cylinders
Post #639559 Sat Feb 10 2024 11:41pm
Wanyer88
Hi there, i purchased the vehicle with the known faults and this was reflected in the price so happy to complete the repairs. Thanks
Post #639571 Sun Feb 11 2024 11:50am
Wanyer88
Thank you for the response and this will be helpful.
Post #639575 Sun Feb 11 2024 12:26pm
