Home > Technical > Tow Hitch wiring diagram RRS 2010
AndyCHO
Australia 2010 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
Hi all
I was wondering if anyone has a wiring diagram showing the standard factory wiring for the trailer hitch plugs?
Connected a trailer up the other day and all works fine apart from the light cirduit.
I checked the trailer but it is definitely working on there... on checking the centre pin (7) for lights there is nothing and all the cabling is fine that I can see.
Looks like I need to take the Passengers side rear inned panel off and investigate what has happened in there but as it was "cabled" at the factory it should all be fine.
I just want to know what connections I need to check in there.
I havent been able to configure any of the 7 pin CCF configurations in the GAP tool to have my rear sensors etc switch off with a trailer on... so maybe it is something to do with the last CCF change I made... I havent used the trailer until just recently since I made the change.
I belive the lights worked ok back then.
If anyone has an Aussie delivered 2010 2011 RRS and their Gap tool... can you let me know what is the standard CCF that works Smile it would be much appreciated.
Post #639505 Fri Feb 09 2024 10:44am
Probably a fuse blown behind the glovebox.
Check your owns manual if you have one
Post #639506 Fri Feb 09 2024 11:30am
Obvious question: have you checked the fuses for the trailer wiring? There's a small fuse box in the boot under the floor. I had an issue with trailer lights once, messed around with the trailer, got lights working by changing wiring around, etc., only to later find the little fuse box and the blown fuse therein.
Edit: the fuse box in the boot was on a MY08 so maybe the 2010 is different. 2012 SDV6 - it's missing a couple of cylinders
Post #639507 Fri Feb 09 2024 11:31am
Don’t think the facelift has fuses in rear
https://www.disco3.co.uk/forum/towing-elec...07122.html
Post #639508 Fri Feb 09 2024 11:32am
AndyCHO
Definitly doesnt have the fuse box in the boot... that would just be too simple... its a LR product...lol
I have had a basic check of the fuses behind the dash but I will need to investigate further.
There seem to be 2 generic Trailer Socket fuses.. one 30 amp and 1 10 amp plus some specific ones for Side lights.
I am doing a 1400 km trip this weekend so wont have time till next week now.
Strange that the indicators and brake lights work.. just the main lights not working yey they are fine on the Rover.
Just something else to track down and sort out... keeps life interesting Smile
Post #639509 Fri Feb 09 2024 11:42am
Above link says it’s fuse 27
Post #639510 Fri Feb 09 2024 11:49am
AndyCHO
Cheers... Another link I found had it as fuse F14 Side Lamp trailer...
I will have a look after the weekend...
Post #639511 Fri Feb 09 2024 11:58am
AndyCHO
Definately Fuse 27... couldnt find my long nose pliers to remove it.. but I will maybe Sunday when I get back.
Thanks all
Post #639513 Fri Feb 09 2024 12:14pm
