![]() | Home > General (L494) > L494 Battery Change |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
Try putting it on a Ctek charger MXS5 or equivalent until the first green light comes on. Might just need a good charge Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
kashifns Member Since: 07 Feb 2024 Location: Slough Posts: 2 ![]() ![]() |
I already charged it once.. I guess Battery is about 5 years old.. And I found the battery as well. It is in Trunk as well. I missed it initially by thinking it is EV Battery.. but it have small lid, when you open, you need to remove a bit of packing material and you see Primary Battery... Weekend project. I hope it will resolve issues.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 440 ![]() ![]() ![]() |
No problem with lion ,,,,Worked in a battery factory ,,,,down the line the plate groups come to be put in different cases with 1 year or 4 year warrantee ....same battery /// You are only paying for lead Always listen to old people or when they die you will live on in ignorance.
