![]() | Home > In Car Electronics > Apple Music on a MY2011 L320 RRS |
Kouze59 Member Since: 20 Oct 2020 Location: North Posts: 8 ![]() ![]() ![]() |
Hi, You can add carplay to your car :
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
I believe you don't have BT streaming in your car (unless equpieed with the later system - rectangular icons on the touch screen) so as said above: an el cheapo BT streamer add-on (minijack into aux input and select "AUX" in the touchscreen) or a proper Carplay implementation are needed.
This is a no go with an iPhone with Lightning or (as in this case) USB-C connection. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Look at the link, it's for a bluetooth adaptor |
Oh, Invery. The link also says:
Granted, it is an elegant solution, but it's also a hit/miss for some. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
