![]() | Home > Technical > Oil pumps/crankshaft failures |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 425 ![]() ![]() ![]() |
the crank failure is preceded by the bearings wrapping on top of each other around the crank which locks the engine and breaks the crank.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
The crankshaft failure issue of the 3.0 and the oil pump failure (noting the oil pump itself does not fail - it is the housing with the cam belt tensioner on it) issue of the 2.7 are not directly related and are separate issues.
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Agreed on the fact that the pump itself doesn't fail except for the very earliest ones, when the cambelt tensioner boss cracks off.
