![]() | Home > Technical > Drop bar links rear |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Nightmare. I guess, supplying the parts outlet with a chassis number is your best bet. |
Yes, they are different...
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 425 ![]() ![]() ![]() |
I think you missed the point which is the two numbers seem to be for identical products but one is twice the price of the other ..... Always listen to old people or when they die you will live on in ignorance.
They have different part numbers because they are different parts.
Both the specs I have say 126mm
Where are you getting your numbers from which suggest ACE and non-ACE are the same? And are you getting your measurements from a retailer or manufacturer?
Wow thanks for all the effort
No problem |
Checked on the friends and mine an they are both ESC and are 132mm between the ends of the bolts.
As far as I can tell.........
