Home > Technical > RRS 2009 Headlight
erickwan
Malaysia
RRS 2009 Headlight
The LHS headlight is not illuminating the road ahead, just 1-2 metres ahead of the vehicle. You can see that the "eyeball" is visibly drooping compared to the headlight unit on the RHS.
RHS is fine. I would assume it's something to do with the internal levelling motor or the linkage etc.
Has anyone on this forum ever attempted repairs, or can the leveling/adaptive mechanism even be accessed in the first place.
Post #639075 Wed Jan 24 2024 3:27am
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Are you talking dip or main beam?
I took mine out to change the main beam to HID and saw no leveling motor....is it not the whole car that keeps level .
Just take it out and have a look ..its only two levers to pull up no screws, Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #639131 Thu Jan 25 2024 8:14am
If the vehicle has the AFS headlights fitted then there is an actuator because it steers the lights when cornering. There is a known failure mode on these where the light "droops".
A search on the forum should find a thread where a member managed to sort this issue without replacing the whole headlight unit. 2012 SDV6 - it's missing a couple of cylinders
Post #639132 Thu Jan 25 2024 9:02am
erickwan
Malaysia
I believe the headlamps work in conjunction with the height sensors and steering angle sensors.
Post #639136 Thu Jan 25 2024 10:34am
