![]() | Home > Maintenance & Modifications > New struts but it's harder than I thought |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 440 ![]() ![]() ![]() |
my new rear struts took about 500 miles to soften up Always listen to old people or when they die you will live on in ignorance.
Thank you |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Isn't this just the normal and expected difference between dampers that are shot (and thus not damping properly) and ones that are new and working correctly? I'd have thought you'd get used to it and your brain will get used to the new "normal" fairly quickly. When I had the rears replaced last year, it just felt like the rear was properly damped rather than slightly floaty. Fronts need doing now, really, so that's another £1200 to find... ![]() 2008 TDV8 - it was a labour of love and is much missed |
