Skelo
have a 2015 range rover sport l494 sdv6
Right, question for the experts.
I've got issues with the amk air compressor, for the suspension of my l494.
About 50% of the time, it will go down as intended to access mode, when put into park and the ignition off.
I've replaced the exhaust filter, no difference, then replaced the electronic exhaust valve (both items bought direct from my local landrover dealer), no difference.
Do you think changing all seals and the granules will finally fix it?
If it doesn't, then I'm at a loss?
The suspension soon will go up and down as it should, when the button in the centre console is pressed. Sometimes it will go into extended height, when trying to get it into access mode, but eventually I can override it.
Wed Jan 17 2024 2:02pm |
Skelo
Drago
Where are the height sensors, and how many are there?
If you know, do you happen to have a picture showing where they are?
If more than one, is it possible to work out if 1 or indeed more than 1 might be faulty?
Thu Jan 18 2024 6:25pm |
