Home > General (L494) > Issue with left side EBP. |
Mac35 Member Since: 15 Dec 2023 Location: Angus Posts: 45 |
Well the car was in at the auto electrician and he said that the actuator just needed calibrated so he did that and was sure the fault was fixed. I wasn’t so sure myself as I did that with my IID tool when I fitted it. Picked the car up and be fault came back after 13 miles driving in very slushy snow, so quite wet. Phoned him and he said to drop it back off, of course the fault went away and was not present while he had it. He had it for 2 days and phoned me, he couldn’t find any issues with the wiring.He said it could be the EPB module. Yet I’ve seen someone with similar issues, he replaced EPB actuator and the module, all be it a second hand module and still had the issue. I drove the car home and again it came back as soon as I got home, around 15 miles or so. Again it was driving in quite wet conditions. So currently I’ve still got the same issue and no further forward. I have noticed that I get faults relating to the rear view camera. I noticed that someone has taken the plastic plugs out of the boot lid that the rear number plate should screw into. I’m starting to wonder if water is getting in via here and dripping on to the harness in the boot lid. Maybe not liked but I have heard of apparently unrelated components causing issue with another.
Wed Jan 24 2024 11:10am |
I'm curious if the fault code labeling could be mixed up either in the ECU or when GAP tool reads it. I was getting the code for the left hand actuator. As i said previously the body was cracked allowing water ingress. Turns out the right hand one was the same, so changed it out and the fault has never came back since. |
Fri May 10 2024 1:24pm |
