![]() | Home > Faults & Fixes > 2006 RR Sport not starting!! Help please |
Eddie_173 Member Since: 13 Jan 2024 Location: Essex Posts: 4 ![]() ![]() ![]() |
Hi all, this is my first tim posting on the forum, I’m a movie with these too so apologies if this problem has been solved else where. The knowledge on these forums is incredible so hoping someone will know how to fix my issue.
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
what's the fuel level? if less than 2 gallons, possibly.. you had it jacked the fuel has moved out of range for the pump. |
Thank you for the reply, no we didn’t break the ABS sensor or power it up with it disconnected. Will give the spark plug check a go today, appreciate it a lot. |
Thank you for the reply, it had 1/4 a tank to start, we did think it may have been the fuel level because of the hill plus being jacked up so we put another 2 gallons in but nothing. Thank you though |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
FIRST POST EDITED TO ADD DETAIL
