Home > Maintenance & Modifications > 3.6 TDI V8 Turbo health
Justinthorpe
New Zealand 2008 Range Rover Sport TDV8 HSE Bonatti Grey
Happy New Year to everyone!
Does not seem to be a lot of info regarding the 3.6TDI V8 out there. Don't have much hands-on experience with Diesel motors.
I have a 2008 RRS 3.6TDI V8 which I'm currently working through some EGR cooler issues, I thought I would remove the two lower intercooler hoses to check on how much oil was there after watching a U Tube video of oil pouring out (albeit with engine running) with blown turbo.
Is that amount of oil from the cooler hoses something I should be concerned about? Toothbrush for size comparison.....
Thoughts?
Regards
Justin
New Zealand
Post #638480 Mon Jan 01 2024 9:38am
TheWojtek
Plenty of information if you put the actual "TDV8" name into search box instead of a non-existent "TDI V8"
No photo of your toothbrush visible here, unfortunately. You just uploaded it and didn't insert into the post, so it ended up in your gallery.
Definitely one (or both) of your turbos sweats oil, some of it has been blown into the intake and burned, this is the residue amount and it would have me slightly worried. How about the dipstick? Any signs of oil vanishing from the engine? A diesel engine should ideally not consume any oil at all, turbo being the usual weakest point of all of them (except for BMW, they fail in all aspects, being great designs terribly executed). Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #638482 Mon Jan 01 2024 12:36pm
that amount of oil is nothing to worry about.
Post #638483 Mon Jan 01 2024 2:15pm
Remember that the crankcase ventilation system blows in to the inlet side of the RH turbo, so there will be some oil present just from that.
https://www.rrsport.co.uk/gallery/albums/u...20PCVt.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #638484 Mon Jan 01 2024 2:21pm
TheWojtek
Shouldn't the oil separator prevent it? Regards etc.,
Wojtek
Post #638485 Mon Jan 01 2024 6:22pm
It should but no system is 100% perfect so there will always be some oil vapour finding its way down there over time. 2012 SDV6 - it's missing a couple of cylinders
Post #638486 Mon Jan 01 2024 8:29pm
Justinthorpe
Sorry, here are both sides.
doesn't seem to use any oil, although I have only had the vehicle for 3 months or so.
Once I get the EGR's sorted out and all back together, will try this with the engine running and see how much oil comes out.
Post #638487 Mon Jan 01 2024 8:42pm
