Home > General > Help with parts information…. 2010 RRS
dave421
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi All
I need some information regards the air suspension struts and height sensors. What i need to know is are all 4 airbags the same or are they in pairs and are all the height sensors all the same ?
TIA
Dave…
Post #638430 Fri Dec 29 2023 7:29pm
Not sure about the air bags, but I do recall something in the w/shop manual about the front height sensors being the same, but the rears are handed and a different colour connector denoting being which position they are located.
Post #638434 Fri Dec 29 2023 9:13pm
dave421
Thank you Thumbs Up
Post #638435 Fri Dec 29 2023 9:16pm
Had a quick look and found this.
Post #638436 Fri Dec 29 2023 9:21pm
NoExpert
On 2010-2013 the sensors are the same side to side
Front struts are the same side to side. Rear struts are different side to side.
Also need to know if you have CVD because the sensors and struts are different if you do. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #638441 Sat Dec 30 2023 5:28am
