Home > Technical > Charge light
stephen_dalton
United Kingdom 2006 Range Rover Sport TDV6 Autobiography Arctic Frost
Charge light
Hi all my charge light has been on for about 2 weeks now but still charging at 13.8 to 14.2 volts had a new starter fitter about a month ago sometimes the light goes out when I have checked the charging state it’s reading between 12.8 and 15 .2. But only when light s out 2.7 sport diesel 2006 help help would be appreciated thanks ste .
Post #638116 Fri Dec 15 2023 3:32pm
gogsy1956
I would say 13.8 - 14.2 is too low,,, should be a constant 14.6/7V . My alternator output began to drop to the 13.8 mark just before it failed completely. Really need to check the current output as well though, not just voltage 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #638118 Fri Dec 15 2023 4:39pm
stephen_dalton
Ok thanks pal
Post #638119 Fri Dec 15 2023 4:41pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
If the charge light is on it means you have a fault ...it does not mean you have no charge but charge can be reduced . Best get a new alternator Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #638126 Fri Dec 15 2023 8:44pm
