Home > Maintenance & Modifications > RRS tdv6 Arc delete belt diagram
Kristian1
Hi all, looking for some help I’ve googled this untill the cows come home bought belts and pulleys and my mechanic. Can’t seem to find a route for the drive belt to bypass the arc pump.
Current setup with arc pump at the bottom, however if you simply bypass it will no doubt rub on the tensioner before it gets to alternator. I’ve also bought a spare braket idler and shorter belt but apprently he said only one hole lines up on the idler.
I then wondered if you need to move the tensioner that’s above down to where the arc pump was as shown in the second picture (green tensioner)
Any help would be greatly appreciated as all I can find is TD5 bypass and no actual pictures of how anyone rerouted the belt. I’ve now bought 2 pumps of eBay and sent both back as they were shot.
Post #637600 Sat Nov 25 2023 4:37pm
Green is where the tensioner sits on a non Arc car.
Mikey says you need a new alternator bracket. (To mount the tensioner to)
Post #637601 Sat Nov 25 2023 5:08pm
Kristian1
Is there a bolt hole for the tensioner though
Post #637602 Sat Nov 25 2023 5:53pm
Disco_Mikey
New alternator bracket, belt and tensioner for a 3.0 Thumbs Up
Post #637616 Sun Nov 26 2023 1:57pm
Or just buy a decent new pump and do it properly. Wink 2012 SDV6 - it's missing a couple of cylinders
Post #637617 Sun Nov 26 2023 2:35pm
I guess the same mentioned parts for a disco 2.7 also work Mikey?
Post #637619 Sun Nov 26 2023 3:26pm
Disco_Mikey
2.7 needs a new alternator too Thumbs Up
If the car in question is a 2.7, I've a brand new ARC pump sitting on the shelf Thumbs Up
Post #637624 Sun Nov 26 2023 7:06pm
Kristian1
How much you looking for? DM me and we can have a deal
Post #637626 Sun Nov 26 2023 7:50pm
Kristian1
Well after much research and not wanting to spend £1200 on the old battle bus arc pump just to drag a bowser round the site. I made my own bracket that replaces the pump.
I would recommend though if anyone wants one for road use, to change the roll bars to standard ones as she’s a bit boaty however I don’t use her on the road.
But if anyone wants one let me know
Post #637774 Fri Dec 01 2023 7:24pm
Kristian1
Post #637776 Fri Dec 01 2023 8:09pm
ZAX1
United Kingdom 2009 Range Rover Sport TDV6 HSE Java Black
Please can you let me know how I can get one of these, this issue driving me mad, 3 pumps gone
Post #642805 Mon Jun 24 2024 7:55am
ZAX1
Post #642806 Mon Jun 24 2024 7:55am
ZAX1
Needings the easiest way to bypass the ACE Pump, im not bothered about having it in use, just need the belt to power everything else .
2.7 HSE L320
Post #642807 Mon Jun 24 2024 7:56am
ashc11
I would love to get one of these dude. Can you drop me a PM?
Post #642951 Sun Jun 30 2024 8:58pm
laurenhelen
United Kingdom 2006 Range Rover Sport TDV6 HSE Giverney Green
Hi, how much for one of them replacement runners to be made? Currently got the same issue and completely stuck!
Thanks
Post #644322 Thu Sep 19 2024 8:47pm
