Home > Technical > Suspension Relay
skullbyka
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
Suspension Relay
Can anyone tell me the reason why replacement Compressors ( in my case the Hitachi) for my RRS 2005 Supercharged are often advertised as coming with a Relay ? if the existing relay is fully functioning is this new relay still necessary or is it merely a "stealership" tax ? I am the darkness before the storm
Post #637312 Wed Nov 15 2023 2:12pm
Could be:
A stuck on relay will quickly burn out a new motor. No one wants that.
Contacts could be poor on the old one due to age.
Post #637319 Wed Nov 15 2023 8:37pm
skullbyka
Thanks Andy - that makes sense 👌 I am the darkness before the storm
Post #637322 Wed Nov 15 2023 9:44pm
erickwan
Malaysia
I replace my compressor relay once every 12-18 months. Increased contact resistance reduces current flow causing the pump to work over a longer period of time.
Post #637671 Tue Nov 28 2023 6:23am
skullbyka
Thanks erickwan - I think I will follow your lead on that and replace mine regularly.
Thanks I am the darkness before the storm
Post #637720 Wed Nov 29 2023 2:17pm
erickwan
Malaysia
I cannot be sure if this results in pump longevity, but the original pump that came with the new car lasted 250,000 kms. It died when the crank bearing disintegrated.
Post #637745 Thu Nov 30 2023 3:40pm
