Home > General > Illumination on rear window switches |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
The center overhead unit is the alarm sensor and infrared transmitter for the wireless headphones if you have the dual view screen and the RSE if fitted, still no light in it though and its shiny black instead. No Expert my comment on window switch lighting was just a general observation if anyone didn't realize, not really aimed at yourself or any one specific.
Mon Oct 30 2023 4:10am |
The rear courtesy/map light is really quite simple nothing special needed, the biggest bug bear is the fact that L/R were a bit tight with the original light wiring but still no big deal, small screw driver, length of wire and a couple of diodes, rather than just twist the new wire around the lamp holder etc. I did solder them on.
Mon Oct 30 2023 8:41pm |
