Home > Maintenance & Modifications > Parking Heater Upgrade
AcePratt
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Hi Folks,
I have a 2010 RRS that has a fuel burning heater fitted. However the car does not have the park heater function enabled and obviously no second remote fob to activate it.
Does anyone know if I can upgrade my FBH to enable the park heater functionality?
Thank you.
Post #636800 Tue Oct 24 2023 3:16pm
33Lurcher
It’s a software upgrade that’s need , it’s needs enabling via an IID Tool that some members have , once it’s enabled you can activate the FBH via the onscreen timer (which will be present after the upgrade) .
That will allow you to purchase a remote/receiver to activate the FBH manually when required . 2016 RRS HSE Firenze Red
Post #636811 Tue Oct 24 2023 7:31pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Everything you need to know is here:-
http://www.rrsport.co.uk/forum/topic24728-45.html
Post #636832 Wed Oct 25 2023 11:15am
AcePratt
Thank you very much all, I will be investigating garages that can do the required SW update.
Post #636958 Mon Oct 30 2023 11:48am
