Home > General > Fuel Burning Heater Question
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up all,
Can anyone confirm my understanding of the FBH on my car, I had one on the X5 so understand how they work, However on my RRS I want to check my understanding after reading info on here Confused
My car is a2012 SDV6 - it definitely has a FBH
The FBH should automatically come on below 5 degrees on start up of the car ( not been below 5 degrees so have not had opportunity to test this I know what to look for / listen for)
There is no timer on my infomat screen nor is it in the Extra Features menu - on 2012 MY i understand I need a dealer / Indy to program this in .
Is there a simple way to test the FBH at all ? Confused
Not bothered about a remote key although would be nice but first want to check what I have actually works.
As always all help gratefully received.
Post #636774 Mon Oct 23 2023 7:40pm
riverblanche
Hi,
there is plenty of reading on this over on D3, it has its own section,
You can download the WTT software for free from Martins site here (or on D3) you can also buy a lead
or make your own to connect to the FBH directly and then run/diagnose the FBH from your laptop
you can also ISTR start the FBH with an Iid tool.
you mention the 5 degrees but there are other parameters as well, battery has to be good and fuel tank level (think it is 1 above 1/4 tank.
you can fool the temp sensor as well to make it start try a search think its in the front grill Question
If your up to changing your CCF files you may be able to enable your timed climate with an IId it depends what model you have Confused
this pick was on our 2005 RRS but same idea.
 Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #636777 Mon Oct 23 2023 8:21pm
TTR
Eh up riverblanche
Thanks for this, I’d read a wee bit on the test rig set up used - just better with spanner’s than owt electronic so not overly confident in trying this out Shocked
It’s got all the potential for me to f**k it right up Confused
I’ve no code reader - thought more than once about LR11 or GapID - just not sure I could fathom it out Rolling with laughter
Read about the other parameters too so confident that the car has all these correct, might try and fool it by using the temp sensor though which is a good shout - will research that option.
I’m not giving up on this want to try and bottom it out somehow
Cheers again - all advice welcome
Post #636812 Tue Oct 24 2023 7:32pm
