Home > General (L494) > Fridge/cooler box installed and not working
Ljason286
United Kingdom 2013 Range Rover Sport SDV6 HSE Baltic Blue
Brought a cooler box for my 2018 RRS stripped out installed cooler found plug not used and plugged in
Not working light on switch not working
Check fuse number 21 10 amp and is good
Does this need to be programmed to the ECU
Post #636229 Fri Sep 29 2023 5:47pm
NoExpert
Maybe because you insensitively called it chubby? It’s just gravitationally challenged.
Have you tried it with the engine running? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636230 Fri Sep 29 2023 6:15pm
Ljason286
Yes when running full voltage
Post #636231 Fri Sep 29 2023 6:17pm
NoExpert
Does it turn on with the engine running?
Mine only works with the engine running, but it’s old, like me. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636237 Sat Sep 30 2023 7:24am
