![]() | Home > Technical > "Restricted Performance" problem. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9023 ![]() ![]() ![]() |
You can get restricted performance from a split inlet manifold. Not sure if it would throw up that error code, however. Otherwise could be sticking turbo vane actuator. 2012 SDV6 - it's missing a couple of cylinders
balaenamick1948 Member Since: 29 Aug 2023 Location: Minster on Sea, Sheppey, Kent Posts: 7 ![]() ![]() ![]() |
Thank`s for that, I`m hoping that is the worse case sinario. From what I have read this would normally be accompanied with a rough idle and mine is very smooth, with a bit of luck it may be yet another silly little RR glitch but would be nice to know if any members have experienced the same. |
