![]() | Home > General (L494) > Rear Caliper Motor Failure |
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 ![]() ![]() |
Yes mine stuck on with the same problem replaced both they’re less than £100 each on eBay
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 180 ![]() ![]() ![]() |
Very, very common, just be sure to get the correct motor as they are model year dependant, either 2 wire or 3 wire, the earlier 3 wire part contains a temp sensor. |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
I’ve had both of mine replaced under warranty with cracked casings Joined the X5 45e club
