![]() | Home > Maintenance & Modifications > 3.0 TDV6/SDV6 oil cooler change |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
Been having a bit of oil come down the back of the valley onto the bell housing lately. Decided I’d replace the oil cooler and oil separator while doing an oil change and other maintenance.
Then install is similar to removal, but this time you’ll end up with a small gap between the oil cooler and the area to the right of the oil separator bracket. You can wedge a flat blade screwdriver in here and twist the screwdriver to wedge the oil cooler past the bracket. Then wiggle and fight it into position. Bolt it back down, get the glow plugs back in, the bracket at the back on, the oil separator in, water outlet (new seals) in, etc. Everything is torqued to 10nm which makes it easy. While the glow plugs were out I took the opportunity to test them, all working fine.
I opted to change the unmarked filter that came with the oil cooler for a Mahle filter.
Not a job I hope to do anytime soon, but I’ve done worse jobs. Went with Hengst intake filter, Mahle CareMetix cabin filter, Mahle oil filter due to independent testing I’ve seen. Also got a sample of the Castrol Edge Professional 5w30 C1 oil I drained to send for analysis at Blackstone Labs. It covered about 15,000km/9,300mi over the past year. It got Ravenol FLJ 5w30 C1 oil this round and I’ll get a sample of it to send off when I hit about the same mileage. After that will be LiquiMoly TopTec 4500 5w30 C1 oil. I’m still running 5w30 C1 despite the LR Time suggestion 5w40 might be better. I did notice with changing the oil cooler to this revised version, the rattle on cold startup has greatly gone down on my 3.0 TDV6. Also threw in some Denso hybrid wipers which are so far great and attempted to get a Denso hybrid wiper in the rear, but it wouldn’t work. Ended up going with a Bosch H403 which does a fantastic job compared to the Trico I tried last time. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory Born and raised in So Cal. Moved to the UK in 2018 for a few years. Now in Poland and looking at moving back to the UK. |
a_a_t Member Since: 03 Sep 2019 Location: Bucharest Posts: 4 ![]() ![]() ![]() |
Hi! Planning to do a similar job on my Sport as well (2012 SDV6) and I've got a few questions for you, if you don't mind, please.
Original is Mann+Hummel. The Nissens is doing just fine with about 10,000km on it. Other than the updated bit you can’t tell them apart. I’ve installed a few Nissens oil coolers and haven’t seen any functional issues with them.
Thanks a lot!
I’d say that, too, changing oil pumps on a 3.0 diesel is a PITA.
I did it at 60K because of age... the car had almost 7 years at that point (first owner did only 50K km in about 6 years... so either the car was used on short trips or was used only occasionally).
That makes sense then.
Good to know that (hopefully) the glow plug job on the 3.0 might be a little easier |
H2OOW Member Since: 15 Dec 2020 Location: Ashburton, Devon Posts: 7 ![]() ![]() ![]() |
Hi
I still have the sample sitting here. Way too much going on and it slipped through the cracks. I’ll get it sent soon and report the findings. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
