Home > General > Solution Finish -Trim
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up all
Whilst still prepping my bumper - sanding needs patience and I needed something else to do🤔
So my rear bumper tread plate looked a little grey - thought about throwing paint on but read about Solution Finish Trim Black.
For the effort v cost of new trim v this stuff thought I would give it a try as I would like do my scuttle panel which looks grey and from what I’ve read is common 😟
So not sure on longevity but prepping as I would paint panel with solvent wipe and made sure trim was clean, left to evaporate, applied solution with foam pad you only need a little it goes a long way.
You cannot really tell in the photo but top is prior, bottom is half done, having left overnight it looks well and will see how it lasts
Will also be applying to scuttle panel.
I’ve no ties to this stuff at all.
Mod - not sure where to put this post so feel free to move it
Post #635147 Fri Aug 18 2023 7:56pm
Stevepd
Good result there and looks nice and fresh. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #635157 Sat Aug 19 2023 8:04am
TTR
Eh up all,
Well besides throwing another primer coat on my bumper as after flatting back just not quite right Rolling Eyes
Hey ho.
Decided to do the scuttle panel after seeing the result on the rear trim panel.
My scuttle was fairly grey and kind of mottled - gather this is normal on RRS
Before :-
After:-
Anyway results below will post back to see how it last
I think it looks a lot better but how long it last time will tell
Cheers all
Post #635347 Sat Aug 26 2023 5:07pm
