![]() | Home > General (L494) > 20" wheels fit over Brembo brakes? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Generally speaking a deeper sidewall will give a slightly more comfortable ride just how noticeable is a another thing. You could run 275/50 x 20" which would probably be a better ride than 275/40 x 22" both are the same overall diameter, 275/45 x 21" some where in the middle I guess but still same overall diameter as the other two, personally the 21" would be my choice.
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
What Col says. For a given type of tyre, more sidewall = more cushioned ride. Also more sidewall = marginally lazier steering, but there is no way to ever really experience this in such a narrow size window. So, here it is:
MadJax Member Since: 20 Nov 2023 Location: Adelaide Posts: 5 ![]() ![]() ![]() |
I recently picked up a 2016 SDV6 HSE and it came with 22inch wheels.
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
I changed my tyres to 275x45-20 and the difference has been quite dramatic.
