![]() | Home > Technical > ZF 8HP70 Oil Flow Diagram |
gt40 Member Since: 21 Sep 2015 Location: Cape Town Posts: 1 ![]() ![]() ![]() |
Good day all. I am busy with a L494 transmission job on a car that I bought (3.0 SC 2014) that had no drive in any gear. During my troubleshooting I found that there was no oil pressure so removed the transmission and then removed the oil pump. A few of the pump vanes had broken which jammed and seized the pump which then resulted in a sheared pump shaft.
