Home > Technical > Removing plastic sill covers. Yes or NO
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
I just purchased a 2009 L320 and have been spraying underside with waxoil..it just has surface rust but should I remove the plastic liners covering the outer sills to check and underseal?
Anyone interested in spraying underseal should read this from my post on Jag forum.
https://www.jaguarforums.com/forum/xk8-xkr...os-271397/ Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #634643 Sat Jul 29 2023 11:25am
I would remove the rear wheel arch liners, and that short wheel arch protector behind the door, as lots of mud and sand can accumulate in there.
https://www.rrsport.co.uk/forum/topic45005.html?highlight=mud
Post #634645 Sat Jul 29 2023 1:01pm
Crp
Removed mine recently, surprised how much mud / sand was trapped especially the near side one. An easy job well worth the effort
Post #634650 Sat Jul 29 2023 4:15pm
DrRob
Remove all liners and sill covers.
Clean
Treat any rust with a rust converter
Prime with a 2 part epoxy primer
Paint with a metal paint.
Lanoguard
Replace liners.
Beer Rolling with laughter Visitor from fullfatrr.com
Post #634671 Sun Jul 30 2023 11:53am
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Pistnbroke
I just got my 12 plate, I could not believe how much mud came out of the front when I took the bottom trim off.
It’s well worth the effort and get it out.
When I washed it the second time water now pours out of the drain holes behind the front cill 👍
HTH
Post #634677 Sun Jul 30 2023 3:45pm
