Home > Faults & Fixes > Sport 2012 no rear camera fix
Barry webb
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi just some info that might come in handy I had the rear camera inoperative and a load bleep when you select reverse.
Most people said the water gets in and you need to get a new camera.
I took the camera out and it was fine no signs of water damage anywhere.
The problem was not with the camera but with 2 of the parking sensors on the bumper so I took the bumper off and started testing the sensors and two were faulty.
Purchased 2 new ones from ebay for under £20 posted fitted them and now everything is working as it should.
Just thought this might be useful to someone with the same problem.
Post #634339 Mon Jul 17 2023 3:15pm
Projectblue
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hi Barry,
When you say inoperative - do you mean didn't come on, but screen went black or nil effect whatsover on the screen?
Post #634893 Mon Aug 07 2023 6:49pm
Barry webb
Hi you can hear a high-pitched tone and it says rear cameras inoperative with a black screen.
Post #634901 Tue Aug 08 2023 8:56am
Grifftheriff
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi Barry-I have the same problem. How did you test the sensors?
Post #637566 Fri Nov 24 2023 10:29am
