Home > General > ARB Replacement
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
ARB Replacement
Have been told that my rear ARB is leaking, and requires replacement. I've been warned that this is a labour intensive job, as the body has to come off Shocked
Would be good to know if anyone has gotten this replaced before, and if so:
1. How much did it cost? (I'm looking to get it done at an indie)
2. With the body off the car - is there anything else I should be replacing? (Car is at 120,000 miles)
Post #634318 Sun Jul 16 2023 4:24pm
Pufftmw
ARC?
ARC's can be got on eBay (proper) for about £750. I've had my done and it certainly wasn't a body off job but it was £1100 or so in all iirc.
Post #634320 Sun Jul 16 2023 5:46pm
Josh95
Anti roll bar?
I guess that’s not too bad! I wonder why I’ve been told it’s a body off job?
Post #634321 Sun Jul 16 2023 6:29pm
peterjj
Australia
The body needs to be lifted a small amount from the chassis at the rear to allow access to remove\replace the bar. Some work but no where near as much work as a full body off.
IF the mounting bolts are stuffed, then maybe full body off to drill them out. Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #634326 Sun Jul 16 2023 11:25pm
Re: ARB Replacement
If they do lift the body off, consider the fixed brake lines that run along the chassis. They're not expensive but basically need the body lifting to do them.
Also, have the crossover pipe on the rear of the engine checked for corrosion. That's an expensive item (£400, I think) but is a body off job (or at least an awful lot easier and quicker with the body off).
Rather depends on how long you intend to keep the vehicle, really. 2012 SDV6 - it's missing a couple of cylinders
Post #634332 Mon Jul 17 2023 7:59am
Josh95
Does anyone know if this would be an MOT fail?
Post #634945 Wed Aug 09 2023 12:50pm
