Home > Technical > instrument cluster fault
blobbt
United Kingdom 2008 Range Rover Sport TDV6 S Stornoway Grey
Hi
and thanks in advance for any help, I have a problem with the following lights and warning showing on the cluster after it was repaired.
the oil pressure warning and the passenger seat occupied light is on all of the time, also the low washer fluid message is showing all of the time too.
I have had the oil pressure checked and all is fine? the seat occupied light goes out when the seat belt is plugged in.
any suggestions?
thanks
Post #634287 Sat Jul 15 2023 9:23pm
erickwan
Malaysia
Yes. Send it back. Laughing
Post #634291 Sun Jul 16 2023 2:52am
Could be the instruments. Not unknown.
Sounds like the weight sensor in passenger seat has failed.
Post #634302 Sun Jul 16 2023 9:57am
blobbt
I have looked at similar posts and it seems to be the cluster has not been repaired correctly, I will arrange to send it back.
Has anyone cloned a cluster if the GAPiiD tool?
Post #634307 Sun Jul 16 2023 11:55am
