Home > Technical > Rough running when cold
John010278
England 2009 Range Rover Sport TDV8 HSE Orkney Grey
Hi
I have a 2009 Range Rover sport 3.6 tdv8 which has started to run lumpy on idle and in drive mainly when cold.
I have blue smoke from right side exhaust and smells of fuel fumes.
My garage has changed both mass air flow meters as it showed up on the diagnostic machine also they have carried out a check using the machine to check the injectors are within the parameters and they all seem to be fine.
Once warm the lumpiness is minimal and no smoke.
Please help as don’t fancy replacing injectors at over £4000 and don’t guaranty it will fix the issue.
I don’t have any warning lights come on.
Post #634282 Sat Jul 15 2023 8:42pm
Turbo getting ready to let go. The oil seal is leaking and allowing oil to be brunt. That'll be £1200 plus fitting, please sir. Each. 2012 SDV6 - it's missing a couple of cylinders
Post #634284 Sat Jul 15 2023 9:14pm
