Home > General (L494) > Fault code P0336-29 Crankshaft position sensor A circuit...
kosio2001
Hi, I'm new here and hope someone can help me. I am the proud owner of a 2015 Land Rover Range Rover Sport with a 3.0 SDV6 215KW engine. I bought the car with a blocked crankshaft after the repair that I did, the engine runs great, but it keeps recording the same error, namely P0336-29. There are no lights on the dashboard and the car always starts fine. A little information about repairs and replacement parts on the engine. New Crankshaft, new crankshaft sensor, new crankshaft ring, new camshaft sensor, I tried new cables from the ecu to the crankshaft sensor as well with a new ecu but unfortunately nothing helped. The error continues to log and sometimes there is a very slight cutoff between 1000 and 1800 rpm as well as a slight vibration in the cabin at Idle. I am posting a few files with the Information which I receive from JLR SDD. Thanks in advance. Have a nice day.
Post #634207 Tue Jul 11 2023 7:25pm
chrisjsw
Was the crankshaft ring a genuine item or Britpart or similar aftermarket?
We recently had to re-remove an engine to fit a genuine part after a new aftermarket ring was found to be faulty 2015 Range Rover Sport L494 HSE Dynamic
Works at an Indy in Herts
Post #634243 Thu Jul 13 2023 3:25pm
kosio2001
Hi, thanks for your answer. It was a genuine ring.
Post #634244 Thu Jul 13 2023 6:27pm
cornwall
Hi, I am curious if you resolved this problem, I have a similar situation. thanks
Post #640413 Thu Mar 14 2024 1:53pm
kosio2001
Hi, unfortunately no and I tried everything but the foult is still here. I don't know what to do 🤷🏽‍♂️
Post #640437 Fri Mar 15 2024 5:32pm
