![]() | Home > General (L494) > L494 Tow Bar and electrics retro fit |
DWA Member Since: 06 Jan 2022 Location: Scottish Borders Posts: 19 ![]() ![]() |
You might want to consider what tow bar you fit depending on the trailer you intend to pull. I have a 17MY Sport with deployable tow bar pulling one of 2 twin axle 10ft Ifor trailers and the problem is the tow ball is not high enough and the trailer pulls nose down. Been to several dealers but all say the same, that there are no alterations that can be made. Interestingly enough measured a Touareg tow ball height recently on a deployable tow bar and the ball height is between 2 and 3 inches higher which would be perfect height, this is a very frustrating problem as rear trailer wheels especially when empty often are not in contact with the ground and especially annoying as what 90% ish of trailers pulled by these cars will be Ifor trailers. |
paulkedwards Member Since: 04 Jul 2023 Location: Worcester Posts: 7 ![]() ![]() ![]() |
Many thanks for the very useful feedback as I've previously always had a multi hight fixed tow bar on the LR's & Discoveries as I also used to tow an IW trailer for move my competition Landy and can imagine it not being level wouldn't make it the most comfortable experience. Life has moved on a little now and my towing needs tends to only be the caravan but the trailer might potentially also get used as I sold it to a friend but there is also the option of using the old trusty 90 TD5. Do you know if the trailer electrics for a 13 pin is a plug and play and the remaining electrics are solely used for the deployable control?
Sorry don't know about fitting, but think it needs to be programed to work properly, mine was a retrofit but done at main dealer, you could always try reversing on to keep the weight back. |
RRS4ED Member Since: 05 Feb 2021 Location: Yorkshire Posts: 43 ![]() ![]() |
I fitted detachable tow trust towbar to my L494 (2014) it was from a 2018 (67 plate so pre-face lift) Taking the bumper out was little bit painful near the headlights, i almost snapped so be careful if you going to do it your self. I would follow torque instructions to the T as its quiet important. Electrics were plug straight in and mine is 13 pin but my trailer 7 pin and little converter works just fine. I managed to code mine self in as it is quiet important, first of all it disables the rear parking sensors when reversing. However you also need it for shifting patterns, suspension and i think even cooling of the engine. I found mine wont go to access height when tow bar plugged in. I cant see the electric one being much different when it comes to coding but you will need the button at least and maybe even the control module. I have to take the little cover every time i have to tow but it works well for me. I recently towed a 3.2 tone of generator which i was impressed with the tow bar and the car. Although the fact that t is detachable does make you nervous although it was rated for 3.5 ton and 200 kg limit on nose. It took me 4 hours to fit it despite instructions saying 1.5 hours but wasnt very bad and it was my first time. Hope this helps |
Thank you RRS4ED as this has answered one of my queries to if there were plug sockets already available to plug the towing electrics into without needing a further loom.
No problem Paul, i didnt cut the bumper but there is a plastic piece behind the cover the chap in video below removes that i had to trim. It was to get the arms connecting to chasis fit through see the blue circles in picture attached.
Here is a video i watched before i fitted mine to get some tips
Wonderful, thanks again. The L494 I saw today wasn’t the one unfortunately so the D4 lives to fight another day. The search carries on 👍🏻 |
Whatever you do make sure it is a well specced and looked after one. Mine is an AB and there isnt a single feature that i dont use. Hope you find what you looking for.
