Home > Faults & Fixes > 2015 rrs ticking
Tanner
2015 rrs ticking
Hi all this is the last thing I wanted to be posting but I have a problem with my car.the engine has a ticking which increases with the rpm.how severe is it[/img]
Post #633863 Wed Jun 21 2023 9:12pm
Stevepd
Hello and welcome. A bit more info is required for others to contribute. What engine do you have fitted. Can you narrow down where the ticking is coming from. Is it there when hot and cold.
Steve 2006 2.7 TDV6 HSE in Cairns Blue.
Post #633871 Thu Jun 22 2023 6:09am
Tanner
Sorry for the lack of detail.it a 3 ltr sdv6 it started on my drive home from work so warm engine but its there on idle and lower rev range then not sure if it disappears or u just lose the noise but it I creases with the revs and sounds top of engine but could be wrong.i did a video but can't upload it
Post #633872 Thu Jun 22 2023 6:23am
Karlp606
When did you last do an oil change on it?
Post #633876 Thu Jun 22 2023 12:15pm
Tanner
only had the car 3wks and was serviced prior to that also has full lr service history and is currently on 43k
Post #633877 Thu Jun 22 2023 12:25pm
Karlp606
Bought private or dealer?
If dealer Id take it back for them to sort.
Post #633878 Thu Jun 22 2023 2:04pm
Tanner
The garage isn't local to me but have been helpfull so far with helping sort a local garage to fix it under warranty ...I've tried it again tonight with a cold engine and the noise is exactly the same
Post #633883 Thu Jun 22 2023 7:41pm
Karlp606
Id leave it to them then dude if covered under warranty, they'll need to see if theres any codes, misfire etc.
Then maybe take top off engine, might be without the motor for a few weeks depending on the repair.
Keep us updated.
Post #633889 Fri Jun 23 2023 8:40am
Tanner
Got to the bottom of the noise just waiting on the full extent of damage but yes it's the crank that's gone it's spun the shell so waiting to here if it's a rebuild or new engine.so much for low miles 40k and full lr history
Post #634061 Fri Jun 30 2023 8:37pm
Stevepd
I'm not sure to say whether you've been lucky or unlucky. I do hope that the garage won't mess you about and get defensive, but you having the car only 3 weeks makes your case rather robust. There are quite a few threads on here and the Disco3 forum with all similar failures and what it has cost them either through JLR or privately funded. Others have walked away from the brand and chosen elsewhere. Either way it's a known problem and it is a lottery on whom it will affect. Putting it in perspective though the amount of engines they produced to failures (or reported on forums) would suggest its a low percentage, but still a bitter pill to swallow.
So what are your thoughts on moving forward?. If they replace the engine would you still want the car or get your money back and repurchase or choose another brand. Please keep us updated on how you get on and what's done about it though.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #634062 Sat Jul 01 2023 5:54am
Turdmon
I'd reject it and go and find another if you really want one. You could be messed about for ages getting that engine sorted.
Post #634063 Sat Jul 01 2023 9:22am
m13lky
As above if it was me I’d reject the car and get a full refund, you will be off the road for months until the replacement engine is fitted and unless it’s done by a JLR specialist there is loads of pitfalls a normal garage can fall into and cause you more problems.
This is the reason I’m in a bit of a quandary about my next RRS, I think I’ll have to go for a 19 plate p400e as that’s what we have at the moment but it’s on a lease which is up next year, a lot of nice AB’s out there as diesel’s but most are tdv6 and knowing my luck I’d end up with this very same issue. I think it will be a p400e AB for us next but buying rather than leasing due to a potential change in jobs for me and I’m to tight to pay the crazy prices for the new model!
Good luck with your issue, hope you get it resolved with as little pain as possible!
Post #634064 Sat Jul 01 2023 11:31am
Tanner
Well it's been a while and 2 replacement engines later I got it back.original engine the oil pump failed causing the crank to fail .New engine in and after 3mile the bearings on the crank failed and seized now on engine number 3 had it back 3 wk and noticed oil leaking so got under to to look and nothing for 3 minutes then whoosh oil everywhere from back ot the engine right hand side by the turbo .the garage are saying its the oil cooler ..any thoughts as I ain't got much co firenze in this garage but the give 12months guarantee on the engine so its there problem for now
Post #636228 Fri Sep 29 2023 5:18pm
