Home > General > Workshop manual incomplete?
ax_crosser
Belgium
I have downloaded the RRSL320WSM2006.pdf file (link found in some threads on this forum). I was searching some info and found some references to chapters that are not in the pdf?
Example from the pdf:
Quote:
Remove the engine cover.
For additional information, refer to: Engine Cover - TDV8 3.6L Diesel (501-05 Interior Trim and Ornamentation, Removal and Installation).
But when searching in the pdf for a chapter with title 501-05 Interior Trim and Ornamentation, Removal and Installation, I cannot find it?
Is the pdf I downloaded only a part of a complete manual? Any ideas where I can find the other chapters/parts?
Post #633417 Mon May 29 2023 7:23pm
Sadly, the version of the manual for the earlier models was missing the bodywork and trim sections when it was first "leaked" as a CD and the subsequent uploads were the same. 2012 SDV6 - it's missing a couple of cylinders
Post #633420 Mon May 29 2023 8:38pm
I certainly have a copy of Section 5, or did have if I can find it, but haven't had my old pre-facelift for over 10 years now, but sure it's on a old hardrive here somewhere.
Post #633421 Mon May 29 2023 9:32pm
ax_crosser
Belgium
I definitely would like to have a 100% complete workshop/repair manual with all the existing chapters/sections. Anyone who can point me to a location where it can be found?
Post #633422 Tue May 30 2023 5:54am
Pay a subscripion fee and download it from JLR Topix.
Post #633423 Tue May 30 2023 7:09am
Raysunners
United Kingdom 2011 Range Rover Sport SDV6 Autobiography Sumatra Black
https://www.rangerovers.net/threads/2010-2...de.330662/
Post #633424 Tue May 30 2023 8:42am
The Section 5 in that link is for the facelift version of the L320. Very similar, admittedly, but there are differences between them. The facelift version might give sufficient clues, however, even where it is different from the original. 2012 SDV6 - it's missing a couple of cylinders
Post #633426 Tue May 30 2023 9:12am
ax_crosser
Belgium
Thanks for all the info.
Post #633437 Tue May 30 2023 7:55pm
As I said,I have a the complete Body & Paint Section 5 pdf for the pre-facelift 05-09 cars here somewhere, if I can find it I will post a link.
Post #633448 Tue May 30 2023 10:17pm
ax_crosser
Belgium
That would be very much appreciated. If someone should have section 3 and/or 4 specific for the pre-facelift 05-09, I would be interested as well (as those are also for the 2010-2013 type on the link posted above).
Post #633450 Wed May 31 2023 5:41am
