![]() | Home > Technical > How much oil should a 90k miles SDV6 on a 61 plate RRS use? |
Robbo969 Member Since: 04 Jan 2023 Location: Wantage Posts: 6 ![]() ![]() ![]() |
Hello all,
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
None at all. Regards etc.,
Thought so...
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
61 plate, so 2011? The drain pipe issue pertains to 2010-2013 3.0 TDV6/SDV6 models. I’ve done it on my 2011 3.0 TDV6 (2012/2013 got the SDV6 nomenclature). Since it sounds like it smokes when you get into the secondary turbo range it’s likely the issue. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
If you wanted a read, some of the pages apply to the fullfat and disco 4 as well.
Thank you all, very informative.
I think it took me four hours to do mine and I wasn’t rushing. Hardest part is getting the starter out and in. The rest is easy. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Personally I would get it done, these things will not cure themselves and possibly will only get worse, the chances of L/R doing it F.O.C are probably less than zero on a 12 year old car. Depending how long you have had the car you could at least ask the dealer who you bought it from for a contribution to the cost of the repairs, because if you don't ask you don't get. With leaving things what may cost £100.00 today could cost £1000.00 tomorrow, unfortunately some people buy these vehicle do the minimum amount of maintenance possible, buy the cheapest parts possible, then when they breakdown etc. they are called a unreliable piece of crap.
I eventually got the work done. Whilst in there they found that the Exhaust Re-circulation on the left bank had a leak and also fixed another hose whilst doing the work... Three months now and it's running very smoothly. And. No oil usage. Thank you for the advice. I just hoped that I haven't cursed the car by saying there are no problems!! |
A 61 plate car will not have a dipstick it has a electronic level sensor/readout.
