Home > Technical > Replacing bonnet latch microswitch
A1GSS
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Hi folks,
2010 L320 TDV6. The alarm started going off randomly, likely culprit is the bonnet latch switch so I’ve disconnected the plug from switch and bridged it temporarily with a handy piece of wire. Ordered a new switch.
Question is, what’s the best way to remove the old and refit the new?
Advice welcome from anyone that’s been there!
Thanks. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #632969 Tue May 09 2023 4:39pm
NoExpert
Just did this last week, very easy to do. Remove the grill, mark the location of the latch so you can get it back where it was, then just remove it, the switch unclips from the base, clip the new one in, get the switch plugged in and bolt the latch back in place to the alignment marks. Think it took me 10-15 minutes start to finish. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #632970 Tue May 09 2023 5:07pm
A1GSS
Great thank you. Is it possible to remove the switch without removing the latch too? Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #632971 Tue May 09 2023 5:13pm
NoExpert
Possibly, if you don’t have ACE/the reservoir in the way. The ACE reservoir is directly behind the latch on mine, it was a pain just to unplug the switch. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #632988 Wed May 10 2023 12:44pm
A1GSS
Ok, I do have the ACE reservoir so I’ll assume I need to remove the whole latch.
Thanks for the update Thumbs Up Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Post #632989 Wed May 10 2023 12:49pm
Pufftmw
A1GSS if not too late - Pics/Howto
No latch removal required Thumbs Up
& you can return the switch probably.
Post #632998 Thu May 11 2023 1:13pm
A1GSS
That’s interesting thank you. I have ordered the new switch but I’ll take a look at the old one before I commit myself to fitting the new one.
Post #632999 Thu May 11 2023 1:48pm
Crp
Thanks, had a similar issue so just cleaned mine.
Result….worked a treat and saved cost of new switch 👍
Post #633230 Sun May 21 2023 12:49pm
A1GSS
Tried to fit the replacement today. Fitting very easy with grille and RH headlamp out, but the bloody cheapo crappy part didn’t work. Inspired by others I have cleaned and refitted the original switch and all working well!
Defective cheapo returned for a refund.
Pic of access with headlamp out:
Post #633315 Tue May 23 2023 11:37am
