Home > Technical > L494 rear diff top up
Nveeate
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi, I want to check and top up the rear diff oil - could anyone please advise how to do this? Thanks
Post #632874 Fri May 05 2023 7:22am
On the L494 just top it up until a small amount runs out of the filler/level plug.
For some reason both pictures mention rear diff, however I think the top picture is the front diff, but sure someone like DM will be able to confirm which is which, although the principle is the same on both.
Post #632875 Fri May 05 2023 7:51am
Nveeate
Thanks Col that’s really helpful
Post #632892 Fri May 05 2023 9:27am
^ mate, if you need to top up the oil in the rear diff, there's a very good chance that the bearings have run a touch dry.
Listen out for a slight whining noise, if you do hear it, unfortunately it will mean a new diff.
Happened to me, and it barely leaked out 2 tablespoons of oil on the driveway. Big Cry --
Post #632899 Fri May 05 2023 4:29pm
