![]() | Home > Technical > will parts from the D3 fit the tdv8 |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Audio, if better. Regards etc.,
Not much from a D3 fits a TDV8
monty19 Member Since: 12 Mar 2014 Location: boro Posts: 323 ![]() ![]() ![]() |
Cheers, there both diesel and auto, thinking maybe the prop shaft would be the same, do you think the wheels may fit from the d3 |
The 19s do fit. Regards etc.,
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
Prop shaft won't fit - the Disco is several inches longer than the RRS and that length is in the prop shaft.
Thanks guys |
