mitdan27
Battery/Upper Tailgate Issue | |
Hi there,
For a few weeks the upper tailgate section hasnt been working. This has also coincided with having a very strange battery drain issue.
The lower part of the tailgate works with pressing the big round button, however the switch for the upper tailgate isnt working. Ive ordered a new switch, however when ive taken the old one off today, it looks like new behind the rubber boot. I have checked with a multimeter and there is continuity through the switch itself and no sign of corrosion etc. Checking for power to the connectors in the tailgate section, its showing as 4.6 on the multimeter, not sure if thats correct.
Ive then checked all fuses and relays relating to the tailgate and all are fine.
This may be a coincidence, but on 3 occasions recently ive had an issue where the battery drains for no apparent reason. The weird part is that it works fine week after week and even when sitting for a period of time, however on 3 occasions now, when ive been washing it or cleaning inside etc, I jump in it and it wont start or turn over at all. Charger shows it down to 10V, charge it back up to 13v and its fine. It may just be a coincidence but ive read a lot online linking the boot issue with the battery drain, I just cant get my head around where the issue would be seen as the switch is seemingly fine and the fuses are too.
Any help would be great! I will be fitting the new switch regardless when it arrives
Mitch
Fri Apr 14 2023 12:43pm |
