Home > General > Odd headlight behaviour L494 MY17
Campreni
Hi all,
I am experiencing some odd behaviour with the front headlights in my L494 2017.
It started with the left indicator ticking fast: turned out the left DRL was not working. However as i was trying multiple things to fix it i also noticed:
- when the lights are set to low beam the headlights are actually on, together with the right drl;
- when the lights are set to main beam the headlights are *off*, but the right drl stays on;
- when the lights are set to full beam the headlights are on (and brighter), right drl is on.
The left drl is always off which in a way comforts me. But the headlight being weird worries me. I have checked fuses ( in the glove compartment and under the bonnet - as far as i can tell there’s nothing headlight related in the boot but please do correct me) and disconnected the battery but no luck so far!
Thanks in advance!
Post #632222 Sun Apr 09 2023 6:47pm
Disco_Mikey
Check the earth point for the headlight. Usually the DRL and indicator start playing up first with a dodgy earth. I don't think that's what's wrong in your case, but its free and easy to check Thumbs Up
Post #632223 Sun Apr 09 2023 7:01pm
Campreni
So i took into the garage and they found a broken wire. I didn't think anything of this until I started reading about CAN injection attacks..... I couldn't find any RR specific information on this but apparently RAV4s have been stolen with this technique....
https://arstechnica.com/information-techno...n-attacks/
And I am now paranoid that thieves are after my car (again)
Post #632997 Thu May 11 2023 9:58am
