Kzwpoas1
![](templates/vbnew/images/spacer.gif)
3 warning lights on.Oil pressure + washer fluid + seat belt | |
Hello,
I read a similar post back in 2021. I have a RRS LR320, 3.6, V8, 2010, 204K kms.
3 warning lights have come on at the same time. Oil pressure warning but the oil level is fine, low washer fluid but the reservoir is full and passenger seat belt warning but no one sitting there!
The previous post and replies pointed to a dodgy instrument cluster but I had the cluster repaired a few months ago by an official dealer. Most likely dry points and poor connections they said. Basically, crap LR quality.
Luckily, the warning lights came up literally in front of the official LR dealer so I went to ask for their advice. They suspect either an earthing, voltage regulation or wiring fault somewhere.
Any ideas?
Cheers.
Sat Apr 01 2023 8:19am |
Kzwpoas1
Thanks Dave, will take a look and check all bulbs. I have heard that one minor issue can cause a cascade of other problems. Too many sensors and way too complicated these machines!
Sun Apr 02 2023 10:02am |
