![]() | Home > Technical > shock absorbers |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
Assuming you have the dynamic programme (the twisty road symbol on Terrain Response), then the dampers are adaptive. You can replace them separately from the air spring but it's usually not worth the effort. I think the OEM is BWI. Otherwise it's LR. Either is pricey but the ones with LR stickers are silly. 2012 SDV6 - it's missing a couple of cylinders
