Home > Technical > OBD port removal
John R Hickman
England 2009 Range Rover Sport TDV6 S Santorini Black
OBD port removal
Hi Guys
I have a 2008 RRS 2.7 tdi and I have been trying to connect to the obd port. My mongoose and sdd won't read anything on the high speed can bus but reads the low speed and others ok. I have also tried 2 blue tooth adapters which wont connect at all. All three devices previously worked on this car ok. I have looked at the port under the dash and it looks like pin 6 is missing or pushed up inside the socket. could this be my problem and if so how do I get the socket out to re pin or replace it.
Post #631535 Fri Mar 10 2023 5:42pm
