![]() | Home > Technical > l494 2013 front active anti roll bar |
They only come as a set of 4 front pipes |
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 175 ![]() ![]() ![]() |
ok thanks , would you know what price that is from land rover |
Dependent on part number, there are a few choices, but the last set I bought was £380 ish |
ok thanks |
i take it the front anti roll bar has to be dropped to change the pipes and has anyone done a write up for the l494 thanks |
Correct |
thanks has anyone done any write ups for a rough step by step for the l494 |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
Workshop manual here: https://www.mediafire.com/file/5hmml7nd29gabm0/RRSL494WSM2014.zip if that helps. 2012 SDV6 - it's missing a couple of cylinders
yes indeed thank you |
