Home > Faults & Fixes > Water inside tail lights |
They look to be after market rear light clusters so that could be your problem 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Feb 25 2023 8:37am |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
pop both light clusters out including the bulbs and if possible use a hairdryer in the light holder's to dry them out if you have someone spare get them to hold a piece of paper around the front of the lense and rubbers as the hairdryer blows inside it should indicate where a crack or if the rubber is apart and letting the moisture in |
Sat Feb 25 2023 8:48am |
