Home > Technical > Adaptive Dynamics Fault RRS 2012 V6
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
Have recently started to get an Adaptive Dynamics fault every time I start the car up. When I try to select one of the terrain modes, I get a fault stating that the terrain response system is not available/turned off (something like that). Car drives fine.
1. Has anyone else experienced this before? What is it likely to be?
2. Is this something I can live with in the meantime until I get it fixed?
3. How costly is the fix?
Post #631132 Fri Feb 24 2023 11:15pm
Initially I would have the codes read, to many variables to guess and could be as simple as low battery voltage.
Post #631134 Sat Feb 25 2023 12:47am
