![]() | Home > Technical > trying to track down a water leak on a 5.0 SC advice |
drexal Member Since: 18 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
I have found a few post on water leaks on the forum and someone suggested trying the USA site as they post a lot about RRS 5.0ltr leaks.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
From what I can see of the oil it looks ok to me, generally if it had water in it, it would be emulsified and take on a milky/grey appearance, how much coolant would you say you have lost over what period of time. I guess it could however leaking from a head gasket water gallery into the cylinder bore which would possibly burn it off when engine running and you wouldn't really know although, if that was the case it may pressurize the cooling system as well, but a "sniffer" test or cooling system pressure test may confirm that. As the leak and tell tale signs appear to show a external leak, initially I think I would still investigate that possibility.
Hey Col and Lrstaylor, thanks so much for replying.
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1194 ![]() ![]() ![]() |
that's probably your crossover coolant pipe that's leaking: sandwiched between the engine block and the supercharger, it will all evaporate.
Here's some info on how to detect this leak: https://www.rangerovers.net/threads/coolan...ll.351574/ --
Hey Naks,
Heres a good video on a guy trying to fix a water leak but a its from a pipe at the back of the engine, not the y pipes, but he's gets into a bit of mess, has to disassemble nearly most of the top half of the engine bay. But he's changing loads of hoses as he goes for rubber ones that he says will last way longer.
Yes, I should have pointed out that when replacing the crossover pipes, to also replace the one at the back, it's the rear coolant water heater pipe: https://euro-amp.com/products/jaguar-land-...and-n-a-v8
Thanks Naks,
^ unfortunately I didn't know about this kit when I replaced the coolant pipes as a preventative measure, otherwise I would have ordered this.
Thanks again for all the help and advice, that price is pretty good for the amount of work, but i bet it will be double that in london and the cost of the kit |
woodsie Member Since: 23 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
Iāve just updated my post in the general section headedā5lt supercharger questionā which all started with a loss of coolant and may help.
Hi guys,
Also thanks for the kit link @naks that looks perfect. I just wish i could find somewhere on here that would help me fit me fit for a days pay as even though the video shows how access it all, i think its to involved for my capabilities. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
