![]() | Home > Maintenance & Modifications > 2010 RRS 3 litre Timing Belt change |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
As an alternative to what?
AndyCHO Member Since: 23 Dec 2021 Location: Wodonga Posts: 125 ![]() ![]() ![]() |
Well for one... non of the prices are from a Dealer so the Ford product may well be the same or similar price and it depends on the manufacture date they have... the last 2 numbers can mean a lot in terms of the latest iteration.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5041 ![]() ![]() ![]() |
Genuine L/R oil pump, latest part number LR123716 from Lrdirect $547.73 + $68.00 shipping. I have received parts from then in 5 days to NZ by DHL. I don't really think any dealer/supplier is going open the boxes up and check the last couple of letters until the find the newest one for you.
Thanks for that info Col. Hmm quite a difference in prices from aftermarket through to OEM both on the OIl pump and a timing belt kit.
Personally for something as critical as a oil pump, I would buy from a main dealer or at the very least from a Citroen/Peugeot dealer as suggested, would not even consider a cheapo ebay etc. so called O.E unbranded god knows made where pump.
100% agree but even with "OEM" branded there are large variations.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Allmakes and Britpart OEM pumps are the proper FoMoCo pumps, with the Ford numbers ground off |
I think DM may have solved you're dilemma for you, reasonable prices for genuine part, without paying double for it to be in a nice white box with a pretty green logo on it. |
In Aust - what is wrong with buying a Ford part from a Ford dealer, particularly when it is cheaper. Why would you bother with Brit Part, Citroen, Peugeot or whatever. 07MY RRS TDV6
Is it actually cheaper from Ford???? I havent had a chance to check with a Ford Dealer but the checking that I did carry out from online sellers was that none of the so called OEM items were original FOMOCO, be it for a Citeron, Peuogot, Ford or Range Rover but were "aftermarket" items.
I put this up earlier - when I bought my pump from the Canberra Ford dealer it was $172 but was a little while ago so will be a little more expensive now. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Are they actual prices?? From my view "about" is probably a guess....
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
My “about” prices are because of exchange rate. I don’t want to say $239.42AUD then the exchange rate make it $245.86AUD a week later. However, those were the prices (+/- $1AUD) when I looked up the part numbers/prices that day I posted. By the way, the oil pump is showing $239.42AUD as of today at current exchange rate. Of course you may get a more or less favorable exchange rate, thus the “about”. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Yes it is a guesstimate as It is a little while since I actually purchased one for $172. You seem reluctant to take note of home grown advice - and why are you on this forum and not our own forum of AULRO. You seem to be making this harder than it needs to be - just ring your local Ford dealer to get a price and try more than one. I just contacted a couple of Ford dealers and know the current price - took 5 minutes but you know it all and I am not now going to do your job for you. Good luck with it ' Endat. 07MY RRS TDV6 Arctic Frost Aspen Interior |
So.. for the sake of honest and open communication on all this... Ford Australia list the oil pump at $318.00 available in a few days.
