Home > Technical > IID tool help
jk3528
IID tool help
How do you change the height settings for the off-road height?
I know how to change the normal height but that has no effect on the off-road level
Post #630775 Sat Feb 11 2023 5:54pm
I did not think you could adjust the heights independently with the IID tool, whatever you a adjust normal ride height to adjusts off-road by same amount, i.e. drop normal height by 10mm automatically drops off-road by 10mm. I believe there is aftermarket systems, Llams Height Kit or something like that being one of them, which allows you to adjust the height independently. Stand to be corrected though.
Post #630777 Sat Feb 11 2023 8:54pm
